Michael Black said:
I had a cheap pocket one, it sold for five dollars, that I was
happy with because of it's small size. I found like a lot of
things, I used it because it was handy, when I wasn't expecting
to use a flashlight that much. It ran off three button cells,
which happened to be the same type as used in cheap laser pointers
taht are readily available here, for as little as $1.99. It
was not a particularly bright light, but if there was so little
surrounding light that I needed it, it was fine. The big problem
with it was that the on/off switch was too easy to press, so often
I found it turned on when I took it out of my pocket.
I gave it away, not to get rid of it, and intend to buy another one
eventually.
I was all set to buy a fancy and expensive LED flashlight, when I wsa
given a Maglite a year ago. Considering the only reason I wanted
an LED flashlight was for it's novelty, the fact that I had a pretty
good flashlight in the Maglite made me put off spending thirty dollars
or so on an LED flashlight.
I don't know how to compare them, but I notice you can get LED bike
lights, with white LEDs, that come cheaper than LED flashlights.
They perhaps are a good balance between cost and output, at least
a step up from the five dollar pocket lights without the full cost.
Michael
I've owned about ten Maglite AA flashlights over the years. I had one that
I kept for almost ten years, then lost it, but....
My main 'work' flashlight is now a 3 - AA LED unit from C. Crane. It's got
some drawbacks, but compared to the Mag's, it also has significant
advantages: You can drop it, throw it...whatever, and the lamp (two LED's)
will not burn out from shock. The LED's don't 'silver up' from use (The
main gripe I've got with the little halogens in the Mag's, is the fact that
after a few hours use, the light output decreases significantly due to the
filament outgassing onto the inside of the envelope). Three AA's are good
for 50 hours at full brightness, plus an additional 100 hours usable light
if you don't get around to replacing them. I use Nimh's, so even that's not
an issue. When using it, I usually just turn it on and leave it
on...something I never did with the Mag's.
The plastic housing is not as solid feeling as the Mag's, but has proven to
be very durable over four years of hard use. The newer units from C. Crane
have active current limiting, according to their website. Mine's just a
housing and two LED's...probably somewhere in there is a current limit
resistor. The switch on mine has gotten intermittant. It depends on
pressing the pc board which holds the LED's down onto a contact; and the
trace where it makes that contact is wearing away...still works, but is a
bit hinky sometimes. Cost was an issue, around $30.
I firmly believe that in a few years time, most flashlights will be LED's,
they're that good. The cost will come down, and they'll suss out how to
concentrate and focus the beam--the main drawback, IMO.
jak
