LED chips and smoking
Hi all, i'm new to electronics and have recently been asked to replace an LED chip in a light, i have soldered the connections and the lamp works but after about 20 seconds there is smoke and the connections break, can anyone give me ant advice?
i've tried using a higher temperature solder but that hasn't seemed to work.
its strange, the LED chip is the same one that the unit uses along with the same control gear, but i still get the smoking off the connections when i put power through it.
some of the reading ive done says to use a thermal paste, would tis make a difference?
