James said:
I was troubleshooting some boards manufactured by a contract assembler
recently and ran into a strange problem. Some of the 1206 SMT ceramic
caps conduct slightly at supply voltage but show open with an ohmmeter.
Jim,
Leakage can be the result of either damage to the cap, or contamination
underneath / around it. Typically a cracked cap will read some nominal
ohmic value on a meter - these parts don't repair themselves once
cracked. Cracked caps can be caused by stressful dapanelization,
mechanical assembly at standoffs w/ screws, pressfit connector
installation, attachment or separation of daughterboards, overclamp ATE
fixtures, touch-up rework with a hot soldering iron, etc. There's lots
of things that can fracture mlcc's. Sometimes mapping out the failure
sites on a grid can lead you to the source of the problem. Do you used
these parts at multiple locations, and do the failures show up randomly
at all of them, or mostly at the same locatins? I think you can find a
nice tutorial on cracked caps on the AVX or Kemet website.
The reflow smt process, lead-free or not, is not likely to crack a
ceramic part. Those assembly profiles just don't have the ramp rate
(typically 2 degrees C / sec) or excursion (250C-260C) to fracture
these parts. Now, a bottomside wave part can easily be cracked. If
the preheat temperature is more than 100C below the wave temperature,
then the thermal shock they experience going over the wave can
certainly crack the larger parts. Once again though, those cracks,
which often are invisible underneath the end terminations, cause ohmic
changes in the parts which are usually detectable with a meter -
several hundred kohm vs. open.
If these are bottomside glue parts - more and more of a rarity in these
days of selective pallets, then you might be seeing something going on
with voiding in the adhesive, which entraps flux at wavesolder. This
has the potential to be a very serious problem, especially underneath
caps which are usually across Vcc-gnd. Certain adhesives are very prone
to voiding and subsequent leakage after wavesolder. The flat
cross-sections look like a slice of tomato with flux in the cavities
between the terminations.
What do you know about the board's assembly chemistry - "leave on" or
OA washable? In general the leave-ons are OK just as long as they're
properly reacted in the process. Left on the board as a liquid, say
for instance when used in a "post assembly" touch-up process where the
operators like to use a flux bottle, they can be trouble. If the board
is an OA process build, then cleanliness is a huge issue because the
chlorides and bromides in those fluxes must be washed off completely.
Look around for any signs of etching around the leads of other smt
parts (QFPs, underneath BGAs) that can be the result of improper
cleaning. Any "fern-like" things (dendrites) growing across these
caps, or smt resistors?
Do these boards undergo any ESS / humidity testing or use in a harsh,
polluted environment (near power plants, dense automobile traffic,
sulfur mines)? All can cause interesting problems with passive
components.
Something else to consider is the layout of the board. Do you have
vias underneath these caps? A tight layout that does this can get into
difficulty with solderballs between the end termination and the vias.
These could look OK on an unpowered board, but show up as you mention,
when it's powered up.
As for the parts themselves, you could have some bad material,
especially if it's coming from a broker. It's worth finding out where
they came from. As for the CM buying the cheapest part they can find
.... that's most likely true; however, CM's typically buy to the
customer's AVL, which calls out the generic component description and
the allowable vendors w/complete part number. I'd be very surprised if
your cap is just listed by value, voltage, tolerance and size, and the
CM is free to buy any vendor's part that fits that generic description.
Your AVL probably calls out a Kemet, AVX, or some other part number(s)
that the CM must purchase. True, they will hunt down the least
expensive part they can within your allowable selections, but anything
they buy will be a part the OEM has specified. No CM that I can think
of would want the liability for a non-working assembly that was the
result of having independently selected a component inappropriate for
the application.
