LCD projector Hitachi CP-X275 lamp ballast repair tech tip
Chris Goulet
Tech tip for the record:
Problem: The lamp fails to light up.
Solution: Replace IC01 (STRG6153)
Details:
The High Intensity Discharge Metal Halide lamp suddenly failed to
light up. A new lamp was installed and would not light up either. The
fan ran and the lamp LED flashed after a few minutes. Voltage to the
ballast module was 368VDC. The ballast did not pulse.
Ballast# PS-226-LS-210 was bad. Hitachi Part# HA01102 was CDN$318 at
Global Electronics or US$210 at Vance Baldwin or US$221 at Part Solver.
The FET series (TR1,5,6,7,8,) seemed good: (drain-source
resistance=5K). Bought an identical projector on Ebay for US$590 to do
comparative multimeter measurements. Found slight differences in STR
G6153. Swapped good part to bad projector, and it worked. This is a
5-pin Sanken brand switching regulator, US$5 at www.electronix.com
Selling the second projector back. I'm happy I could fix this for the
price of 2 Ebay transactions.
dslsauger
I bought a projector in Ebay too.
After a while I have the same problems as you have.
I send it to be repaired, but they said the balast ist bad und it woul
cost nearly 250 Euro.
Ok, thats too much.
Now I found your thread and I messuerd the FET series.
It is interest what I found, because TR01 has not 5K ohm.
Maybe thats the problem.
But how could i look after the STRG6153 is broken?
Also know somebody how to wire the 4 cable from the balast, to use
xenon lamp instead of the orginial one?
Ok I know i have to use an external power supply and so on.
But the only problem i have now is, which cable are used for checkin
if the lamp works.
I could only be one of the four one.
three are brown and one is yellow.
Sorry for the bad englisch but I'm doing my best to good english.
(German studend)
Thanks a lot,
Dslsauge
