LATHE, 13x40", SW Oregon, bad threading-gears, rest is good, $500 obo
metal
Sunmax 13x40" gap-bed lathe for sale in southwest Oregon (Medford);
only 25 minutes off I-5.
Similar to "heavy duty" Jet model. 1500-2000 lbs.
The gearbox that drives the threading motion is trashed; but the
bed/ways and spindle look good.
Excellent machine for CNC conversion; or you could still use it
manually with cross-slide as feed for short cuts. All axes of
Cross-slide seem in very good condition....smooth...snug....minimal
lash.
Nice lathe....3hp motor, hydraulic-disc spindle-brake, camlock
spindle, etc. etc..
Has been kept under cover...only light surface rust from occasional
humidity. Should clean up good.
The leadscrew itself is still there. The gearbox cover with the
shift-knobs is not. Don't think it matters though, because the
gearbox isn't worth fixing.
The gearbox that drives the spindle appears to be untouched, and the
spindle turns very smoothly....bearings seem like-new tight.
The stand is real nice, and probably worth a few hundred by itself.
The tailstock casting is also still there. Not sure if all parts for
it are there; but I did see the handwheel and some other stuff next to
it.
Take the whole thing for $500 cash, or make best offer. I need it
outta here....getting ready to move.
To see picture and details, click this link:
http://www.oregonstone.com/forsale-misc.htm
Will trade for plasma-cutter; large propane fridge that chills well;
flatbed trailer; 5th wheel; diesel genset, pump, or engines; heavy
equipment stuff...??
I can load your truck or trailer from overhead using a Cat 966 loader;
as long as it's not obstructed by a topper, lumber-rack, or whatever.
Email me at: metal at fullwave dooooot com
or call Richard at 541-944-9746 after 1pm weekdays; 10am-7pm weekends
