Tim Wescott wrote:
20kHz? That's like molasses. Why so low? And it should not cause it to
oscillate.
If he's already got substantial phase shift elsewhere, then the photodiode
rolling off would cause oscillation somewhere around 20kHz.
The fact that it happens at _exactly_ 20kHz just means that, sans
photodiode, he's got about 45 degrees of margin at 20kHz.
But where does all that phase margin fall through the cracks? Unless
everything rolls off fast, of course. 20kHz BW for the photodiode sounds
really low, unless it is one the size of a dinner plate.
Regards, Joerg
http://www.analogconsultants.com/-Hidequotedtext -
- Show quoted text -
Grin, well not quite dinner plate size. ~6-7mm diam.
That should be a lot more zippy than 20kHz if connected to a somewhat
reasonable TIA. Or did you give it a hefty dose of Ambien?
Grin... I posted numbers for Tim. I can get a factor of 2 or so by
reverse biasing the PD, and maybe a factor of 5-10 with a faster
opamp.
Then it's time to flick the little switch on the Weller and do that
Reverse bias is easy if there is no compelling reason why you need to be
photovoltaic with the PD. Just keep the abs max limit in view. With the
opamp also keep in mind its slew rate. GBW means nothing if it can't
swing its tail around fast enough.
Grin, yup, that's fine for me. Not so easy for most customers.
