Ok - so I have a train going around my room - this train has a semiautomatic uncoupler. The uncoupler is just a coil that when activated creates a magnetic field that pulls the knuckle couplers on the train apart thus disconnecting the cars. It needs 3 amps at 16-18VDC. I purchased a laptop power supply which provides 18VDC at 3 amps. I cut off the ferrite bead and hooked it up. It overheats the uncoupler immediately. I contacted the designer of the uncoupler and he said that it should not ever overheat at 3 amps 18VDC so he sent me a new coil and the same thing happened. There are no shorts - and everything is hooked up properly. I tested the supply with a multimeter and came up with 17.2VDC and varying amperage - it went all over the place from 2 to 6 to 1 to...... I thought the supply was bad so I tested my actual laptops power supply and it did the same thing - except I know this one is good because it charges my laptop everyday. I hooked the coil up to a train power supply that ran at 17VDC at 2 amps and the coil did not overheat but did not get enough power to pull the couplers apart. I thought maybe its the multimeter - so I tested the train power supply and got a steady 2.3 amps at 17.1VDC - so the meter works. Are laptop power supplies different that regular ones and if so what part of them creates this jumpy amperage so I can take it out?
ANY help WILL be greatly appreciated.
THANKS!
THANKS!
