Electrolyte: An electrolyte is a substance that will dissociate into ions in
solution and acquire the capacity to conduct electricity. The electrolytes
include sodium, potassium, chloride, calcium and phosphate. Informally,
called lytes. (The clue to the word electrolyte is in the lyte which comes
from the Greek lytos meaning that may be dissolved.)
[unquote]
If you look up "solid electrolyte" you will find that there are many
compounds that are considered electrolytes that contain no water and some are
even solids.
The SM chip left of C34 is probably an electrolytic, as are the two above the
marking C518 on the topside picture. On the bottom, the two chips I mentioned
before are just to the right and above the marking R678, another is above the
marking 07/03/17 on the heat pipe in your bottom picture.
But we have wandered far afield of helping the OP fix the problem with his
laptop.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
