Platforms
Content
the launch board with the power button was tested on another motherboard and it work well
try to check cmos battery then try tu plugin without it.As soon as I plug in the power adapter into the power jack the laptop turn on automatically . I don't have to press the power button !
Any suggestion where this problem comes from ?
ok after checking removed the power jack and reapply it the issue changed , now the power is on for 5 seconds then off and if press on again the same happens , meanwhile the processor fan is not getting power as it doesnot turn on while the fan itself is checked and working fine
where to go now?
No, lol but will watch a little better, but its cause im 7*9Doc, did you notice this thread is ~7 years old?
