Joseph Legris
Jim said:Not this one. It BURNS an image... not your usual heat sensitive
paper.
...Jim Thompson
That sounds nice. My lousy BROTHER labeler uses the stuff I described.
What make is yours?
paper.
...Jim Thompson
I've used standard paper labels with sticky backs (ie address labels),You mean printing on the sticky side? Is that possible? I fear for my
printer.
Very old ,called "LETRASET" and also came with aJason said:Hi guys,
I have a few plastic (mainly ABS type) boxes that I put my completed PCB's
into. I want to label all the LED's and switches etc. somehow onto the box
itself without making a stick-on "label" as such. Is there some sort of
lettering you can buy that you can do yourself instead of getting
silk-screened professionally? I want it to look professional but don't want
to spend a lot of money.
P.S. I have tried the "clear inkjet labels" that you can print on, but find
it's not very transparent and rubs off easily.
Any ideas?
Please provide web links if relevant.
Thanks in advance.
Jason.
Jason S said:Hi guys,
Any ideas?
Adrian said:Overhead projector acetate film, laser printed in mirror-image.
Stick
it on with double-sided carpet tape so that the printing is on the back
(and now reads the correct way around) and cannot be rubbed off.
It is also quite acceptable for front-panel labels on non-commercial
equipment.
The ony disadvantage is that the carpet tape provides a very dull white
background. You cannot use clear liquid adhesives because the solvent
will dissolve the lettering.
What make is yours?
... My lousy BROTHER ...
If you can live with a white decal, use polyester stickers from
Avery/Zweckform, type 4776. You can print on them with a laseprinter and the
result looks very good.
Look at http://www.shipmodul.com/en/miniplex-41.html for an example.
Meindert
Pooh Bear said:Yes, I've done this.
There *is* clear double-sided tape around.
Spray adhesive works too. Look for the Scotch brand spray adhesive sold in art
shops.
Adrian said:That's worth knowing, have you any idea what it's called?
Is it as sticky as carpet tape?
I's be a little uneasy about that, I thought it was for mounting paper
and card and didn't stick particularly well to plastic or metal panels.
Chris Carlen said:"4776" doesn't find anything on Avery's catalog search. Is that the
correct number?
Pooh Bear said:Not being funny - 'double sided tape'.
It's pretty tenacious. We used it to stick 'leatherette' to wooden trim for
example.
Adrian said:OK, thanks. I'll try to find a source of it.
http://avery.com/us/Main?action=product.HierarchyList&node=10211066&catalogcode=WEB01Chris said:"4776" doesn't find anything on Avery's catalog search. Is that the
correct number?
ehsjr said:http://avery.com/us/Main?action=product.HierarchyList&node=10211066&catalogcode=WEB01
6575 through 6579
Meindert will have to verify that its the same thing -
I just assume it is.
Richard H. said:Try 3M Super 77 (http://tinyurl.com/43eqc). Very sticky, bonds to most
stuff, and holds strong. Buy it at the hardware store. It's different
from their Artist's Adhesive, which I haven't used.
Full URL:
<http://products3.3m.com/catalog/us/...unting_3_0/command_AbcPageHandler/output_html>
(Someone needs to educate their web developers about easy-to-forward
URLs...)
Cheers,
Richard
Second technique is to first, print it on one sheet, place the sheet onYou mean printing on the sticky side? Is that possible? I fear for my
printer.
Pooh Bear wrote:
