@Damien...
Uhh here's the thing Dave I've been working with 240 for a few years now. You really think I should go back to low voltage stuff?
YES. I mean no disrespect, but you should absolutely "go back to low voltage stuff". Regulatory laws, rules, codes and ordinances are in place to protect life and property, circumventing those safeguards without certain knowledge of the ramifications is a fools errand with potentially dire consequences.....Most modern power generating stations output in excess of 1 Mega Watt and typical residential mains transformers will supply 30kW or more of that power without hesitation....the latter is roughly equivalent to instantaneously igniting an entire gallon of gasoline under ideal conditions...while this same gallon of gasoline is relatively safe to ignite a few mg at a time in an internal combustion engine, it could also be weaponized to have a kill radius of > 250m^2....just because gasoline and electricity are readily available and commonly used does not imply they are inherently safe or that they are to be handled casually. I would encourage you to learn about electricity and electronics behind the safety of galvanic isolation or from a less potentially lethal source than mains power....As far as working with 240V mains.....as long as what you do meets or exceeds standard safety codes then by all means carry on, but when what you are doing is well outside of safety protocols, borders on outright danger and you repeatedly demonstrate you do not understand the general concepts in play, then I think it might be a good time to "go back". I will add, that as long as you are only rewinding the secondary of the transformer, (and you observe insulation and environmental concerns) you should be relatively safe....Typical microwave transformers are less than 1500VA and while not a trivial amount of power, typically not lethal.
As far as recharging your batteries while camping, I would suggest you consider a marine battery charger designed for safely charging lead-acid batteries from 120Vac/220Vac (either mains or generator supplied). While marine battery chargers are considerably more expensive than automotive battery chargers they are designed to be safe in wet environments....a big plus when camping. You might also consider simply purchasing a generator specifically designed for charging 12V batteries...they are typically light-weight, fairly inexpensive, very quiet and as an added bonus they are really safe
At any rate, if you do continue with your microwave oven transformer retro-fit, you should consider the fact that a 12V lead-acid battery nominally rated @ 12Vdc will typically require a 14V or higher charging voltage....And you should be aware that typical AC voltage readings are RMS values...the no-load rectified DC voltage of a 12Vac output will be ~ 17Vdc....and just to wrap things up, a properly wound 1200VA transformer with a 12V secondary should provide roughly 100A....which is suitable for welding....any electronics you are considering should be designed with this in mind....FWIW, a microwave transformer will have a very short life if tasked @ even 50A for any length of time, the heat build up in the secondary and core will be tremendous....remember, heat losses = I^2 R, so @ 50A even 100mOhms of resistance ==> 50^2 * 0.1 = 250 Watts in heat from the secondary alone. Thermodynamics is not really my strong suit, but I think it fair to say that failure would be eminent ....I will leave any haggling about the ETA to others......
Fish
