L298n connecting in parallel
Hello! I would like to ask for some advice or help if my wiring is appropriate as shown in the photo. I am using 2 L298n motor drivers to actuate 4 peristaltic pumps (runs @400mA each, hence, 1.6A total max current when all pumps actuating). I am powering these modules using as 12V power supply in parallel and will be hooked to a Raspberry Pi microcontroller for control. I am wondering if such parallel connection would be ok and if are there any problems I might encounter since I it's my first time handling with motors for my small automation project. Thanks!
Bear in mind that the start-up (stall) current of a DC motor will usually be several times its normal running current.
I see. If I understood it right, you mean I would have to mitigate those spikes at startup and maybe use smoothing capacitors? Just like what the previous post suggested
bertus
Hello,
As @Alec_t said, the start-up (stall) current can be much higher.
The start-up current can be upto 5 times the running current.
So 2 Amp for each pump.
Do you have details on the used pump?
Are there other currents given in the datasheet?
Bertus
bertus
Hello,
You could parallel two channels of the L298 to drive one pump:
The complete schematic would be this for the 4 pumps:
Bertus
  • L298.pdf
hmm, so connect the two outputs on each side? initially it would have been +out1, -out2 and vice versa, in the above schem, where does the ground go?
