Hey . . .Youse Guys . . . . .
As per . . . . .
Maybe the output device is shorted TDA7296
If that
TDA7296 unit is bad one would expect the power outputs built within it to be bad.
How about taking metering in hand and set it to ohmmeter function and at its lowest range . . . . unless your unit is autoranging and it will seek it out.
Then you find the Black / negative meter probe and pin prick into IC5 pin 1's solder blob.
Then use the red probe to test pins 8 /same conn / 15 to see if there is either a very low resistance or dead short.
Then move the red probe to test pins 7 /same conn / 3 to see . . . . you guessed it . . . if there is either a very low resistance or dead short.
If that was not found then we might wonder if it is only under powered up conditions that it fails .
So lets look at the boards foil pattern snippet below, note the short
RED and
BLUE delineation lines.
Get a single edge razor blade or an Xacto knife with a # 11 blade chucked in and
BRACE your fist and slope the blade to the right and cut the right BLUE dotted line.
The move up to the RED dotted line and cut it at that same cutting slant.
Now move to the other sides dotted lines and slant the blade slope to the left and do those two cuts. You only need to have a narrow slit opened up to diisconnect power flow.
The use of those non vertical / sloped cuts should then facilitate getting a centered strips end corner foil initially pried up , using the blade tip and then peeling up the whole central strip.
Check for continuity, to be sure that the foil was completely opened.
Then power up to see if any fuse then blows. If not, expect the TDA7296 as internally bad.
If still blowing the fuse . . . . did you initially overlook FWB diodes D14-15-16-17 or main filter caps C48-49 ?
Widening the foil gaps by scraping to bare copper and pretinning both sides and then using a brigdging solder reflow fillet should restore your foil cuts.
FOIL PATHS . . . . . .
Product TDA7296 . . . . .
https://www.mouser.com/ProductDetail/STMicroelectronics/TDA7296/?qs=/ha2pyFadugE/UPLZoVc02JfJIBQ/rENc4uOPrkDCwg=
73's de Edd . . . . .
All TRUE WISDOM . . . . . is usually to be found . . . . being displayed on T-shirts.
