L
Lenny
Hi there
I'm working on a model 250 amplifier that came into our shop for
repair. The customer reported that the unit smoked when it was powered
up. So far I have found the following defective components:
1. Q4, Q5, Q8, Q9, drivers open
2. R35, R25, .51 ohm resistors open
3. Q12, Q13 output transistors shorted
4. R27, 681 ohm base resistor for Q7 open
This seems to be an an inordinate amount of component failures on this
unit. I've never seen all the drivers on a unit open. Is this a usual
occurance on this model? Also, are these parts still available or can
I substitute?
Some other questions; Can I get away with just replacing the two
shorted outputs or should I change them all? Is it critical that these
outputs and the drivers are matched and how tight is the spec on that
681 ohm resistor? I have checked everything else on the output board
and have not found any othr problems as of yet however I was wondering
if given what I've already mentioned, its felt that I've covered all
the bases, or might there be other things I should look at as well?
Thanks very much for any help and advice.
Lenny Stein, CET.
Barlen Electronics
I substitute?
Lenny Stein, CET.
Barlen Electronics
