Michael A. Terrell
default said:Well you already have enough responses, but I'll dive into this fray
anyway. The crystal set was my first introduction to electronics. I
was five and could barely read enough to follow the directions to
build that first "Philmore" crystal set kit
Add an amplifier? That's cheating.
Good antenna and ground and you should get enough signal to drive a
loudspeaker in many cities. The problem today is it is hard to find
those "Cannon" 2,000 ohm dual coil magnetic headsets - crystal
earpieces are no where near as good.. Equally hard to find a 2K ohm
to 8 ohm matching transformer to drive a speaker.
Use the common and 2.5 watt taps a 70 volt line transformer, and you
have a 2000 ohm primary. The secondaries are usually 4, 8, or 16 ohms.
Cheap, and easy to find.
Here's the mother load of crystal set designs
http://www.crystalradio.net/crystalplans/index.shtml
The one I built in the 50's that worked a loudspeaker
#74 on the crystal radio site (same site as above)
someone else with the same radio on their web site
http://hibp.ecse.rpi.edu/~john/xtal.html
http://hibp.ecse.rpi.edu/~john/xtal_pict_b+w.gif
http://hibp.ecse.rpi.edu/~john/hi_power_xtal_set.gif
There was one in the 60's or late 50's that used a single transistor
that drove a speaker - that needed a volume control. It was a reflex
type - one transistor amplified RF and audio. I think it was in Radio
Electronics but I haven't found it on line.
Then Philmore came out with a two transistor kit that could drive a
speaker with no ground or external antenna.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
