Phil Allison
"Bob Parker"
** This is a pedantic and misleading comment - the hot tip IS the source of
voltage in a thermocouple used in the normal way.
Or, more precisely, voltage is only generated where there is a temperature
gradient along the pair of wires coming from the joint ( or tip) to the
meter.
The magnitude of this voltage depends ( in a non-linear way ) only on the
actual temperature difference - so the length of these wires becomes
irrelevant.
So - if the tip it at a certain temp, you will get the same voltage output
at the meter as long as NOT all the wire leading to the meter is at a
different temp to the meter.
...... Phil
From http://www.sensoray.com/support/tcapp.htm .....
"There is a misconception of how thermocouples operate. The misconception
is that the hot junction is the source of the output voltage. This is
wrong. The voltage is generated across the length of the wire.
meter.
irrelevant.
...... Phil
