Hi
I'd appreciate some advice re installing a K Type thermocouple, with a small stub end, into a brass block. The brass block will be used to heat and blue steel screws and clock hands. A PID temp controller will be used.
Obviously I will need to drill and tap a hole to receive the retainer bolt/screw on the thermocouple. I am thinking at the end of that hole there needs to be a recess to snugly take the end of the thermocouple node, is this enough? do I have to use some sort of heat conductive gel or paste? If so, any suggestions what it is I should use?
The temp will go up to 310deg Centigrade.
Thanks in advance.
Thanks in advance.
![jkd-thermocouple-k-410x300.jpg](/forums/proxy.php?image=https%3A%2F%2Fjkdevices.com%2Fimage%2Fcache%2Fdata%2Fsensors%2Fjkd-thermocouple-k-410x300.jpg&hash=59e6858fc77c9c5ccc78083785c60b56)
