Platforms
Content
I really have no idea what is wrong with it. I do not know much about speakers so keep that in mind.
It is getting power in both the left and right channels.
hi
welcome
so one speaker works but the other doesn't ?
not sure what you mean by that, please clarify ?
do the wires to the speakers just disappear into the speaker cabinet, or are there connections on the backs of the speaker cabinets ?
One speaker does work
If it works its not the speaker .... right?OK
so what happens when you move the possibly faulty speaker to the working channel ?
is it dead or does it work ?
this determines if it is a speaker or amplifier channel that is faulty
OK
I put it in both channels and it still didn't work, I also switched the cables and nothing. I'm sure it's the speaker. But it's getting power.
I already opened it up and no wires are broken or look wrong.OK that would indicate that you have at lease 1 speaker faulty
open it up if possible and see if there are any broken wires
it is possible for a speaker to fail without any obvious signs
is it a single or multi - speaker cabinet .... please show a photo of the inside of the cabinet
so I can clearly see what wires go where
YesIt is unlikely that all 3 speakers are burnt out unless it was connected to 120VAC for a fireworks show. Therefore I suspect that its main input wires are broken or quick disconnect connection has a bad crimp.
Is this the connector on the rear?
When I set me multimeter to 200ohms, I get 0.05 on the screen for the sub. The one in the middle is getting 016 MΩ and it's set at 2000M. That one seems a little odd. The third one, also the smallest is getting 010 MΩ. That seems like a big difference. Either I did something wrong or it was the speakersWhat do you mean by 'getting powe'. Some speakers come as a pair with power going in to one box to supply an amplifier which drives both speakers.
If the speakers are the more powerful type with just a red and black lead going in, take an analogue meter, set it to the lowest range and measure the resistance between the red and black wires. A good speaker will measure about 5Ω and there will be a click when the meter is connected.
Edit
Got the pictures at last. They are three way speakers with some crossover components in a bass reflex cabinet. Measure the resistance across each driver.
Note that when the back is replaced it must be sealed to get the right frequency response.
When I put the multimeter to logic (I think that is the one for connection) and hook the multimeter up it makes the noise. https://imgur.com/gallery/RjlVOstill don't know what you mean by getting power ???
put the good speaker on the other amplifier channel and see if it works
or if you have another old speaker lying around use it instead to save risking the good working speaker
show a photo of the back of the amplifier so we can see where the speaker lines terminate
examine the speaker wire VERY CAREFULLY for the faulty speaker see if it has been damaged
I think I have found my problem, there is a capacitor that is not working going to the middle speaker
