Dave Moore
Tip;
Look for damage wherever glue was used.
This set had the wires in a couple of ribbon cables
eaten away where they were glued to the PCB's
Question;
Also the glue damaged a zener diode and ate away
the identification markings on it. To make matters
worse, the bugger was shorted so I couldn't measure
the zener voltage.
From what I could see, there was a "1" and also the
bottom part of either a 6. 8, 3 or 0, so it was probably
a 10, 13, 16, or 18V zener
The set is working with a 16V zener in there now,
but I'd like to stick to the original value if anyone
knows or can look it up for me.
Any help will be truly appreciated.
--Dave--
Question;
the zener voltage.
--Dave--
