I've build a Jacob's Ladder with an old "Franceformer". The specs
are:
Input; 120 volts - 60 Hz. Output;14,000 volts- 30 Ma.
If I wanted a bigger show and had two identical transformers, could I
stack them for a bigger arc? Would this even be prudent? If not why
not?
If it would be possible, would I wire them in a series or parallel
configuration? If not why would it not work, and what are the
pottential hazzards?
There are some transformers out there that don't stack in series well
because the secondaries have points somewhere or somewhere else either not
too well insulated from, or outright connected to, the primary.
An example is neon sign transformers. Most have secondaries with their
center taps connected to the case. I doubt the insulation between the
primary and the case withstands reliably, maybe usually not at all, half
the secondary voltage.
If you put two neon sign transformers in series, their cases will have
one full secondary voltage between them. Even powering the primaries with
isolation transformers can be a problem if interwinding capacitance is not
greatly smaller in the neon sign transformers than in the isolation
transformers - insulation breakdown even with the low current flowing
through interwinding capacitance will cause a problem sooner or later, so
in an isolation transformer scheme you need to connect one end of each
neon sign transformer to its case. You will need two isolation
transformers that withstand reliably half the secondary voltage, or one
that reliably withstands the full secondary voltage.
I think this gets Rube-Goldbergish and is asking for big trouble.
Two neon sign transformers in parallel will give you an arc of same
starting length, but that will stretch longer before it breaks. However,
if you get zapped you are more likely to die.
- Don Klipstein (don@misty.com)
