Hello, guys. Totally new guy here, so sorry for the rookie question. Any help is greatly appreciated.
I am working with an automotive 12V DC circuit. I have a BCM that sends a flashing voltage (turn signal), or a constant voltage (brake lights) to a bulb via the same wire. I am trying to eliminate the brake signal, and use this bulb as a turn signal only. Is there a way to "filter out" the constant 12V when the brakes are applied, but allow the flashing signal to reach the bulb for turn signal?
I would imagine reprogramming the BCM would be the easiest way to do this, but I have no access to the hardware or software to do it. Can it be done externally, such as with relays or SS devices?
