I am putting together a PCB that has a CPU to control the on-off state of a high power IGBT. There are two power supplies associated with this:
1) A 24 DC lab PSU that is regulated on the PCB to both 5V (CPU) and 15V (TC427 MOSFET driver)
2) A meaty 150V / 40A DC PSU that flows through the IGBT and into a massive inductor
The trouble is, I'm nervous about connecting the grounds of both PSUs together due to my suspicion that in certain conditions in my application I'll get large negative currents on the ground plane and/or other nasty stuff that the CPU and related electronics will hate.
However, if I dont I have a concern regarding getting the correct 15V gate voltage to turn the IGBT on and also another circuit where I use a 2-resistor voltage divider to downscale the 150V to a meagre 5V so that it can be fed into one of the CPU's ADC inputs to measure the incoming voltage.
Can anyone suggest a way forward?
