I live in Canada. I have a "made in Britain" machine that I bought from the UK, that I want to use here in Canada. To do so, I bought a step-up/step-down voltage converter, though I don't know if it contains an internal regulator. Some voltage transformers contain an internal regulator, though these are more popular in 3rd-world countries or very remote areas of 1st-world countries where the power supply isn't as stable, I've heard. Should I trash mine and buy a more expensive one that contains an internal regulator, such as one from http://www.voltagesuperstore.com/voltage-converters/110-220-volts-converter-5.html ? If I can't find a 3-pin plug adapter (that will touch the two thin flat earthing contacts on the plug of my transformer, then would having an internal regulator allow me to use a 2-pin plug that goes into my wall outlet/mains supply? I am most concerned about how only 2-pins are entering my wall-outlet, and that there is no metal on that thing that is touching those thin flat metal contacts, as you can see in the photos I've taken near my wall outlet/mains supply.
What are the risks of using the setup that I have right now? Could my machine get damaged since I suspect it isn't "earthed"? Or would I just get electrocuted myself, but my machines would stay safe?
I tried looking on eBay for a wall adapter that would touch those flat thin metal contacts, and also have 3 pins that enter my wall, but I didn't find any (not that I spent much time looking). Can you please give me some links to where I can buy such an adapter, on eBay or elsewhere?
Please look at the 9 photos I've most recently uploaded here: http://anannymouse.imgur.com/all/
Please let me know if you're unable to see the 9 photos. It's important to me that you look at them.
The paper wrapper that was around the Sterex power plug (that would plug into a wall if I was living in the UK, I would assume) says,
"IMPORTANT:
The wires in a 3 core main lead are coloured in accordance with the following code:
Green & Yellow - Earth
Blue - Neutral
Brown - Live
As the colours of the wires in the mains lead of this appliance may not correspond with the coloured markings identifying the terminals in your plug, proceed as follows:
The wire which is coloured Green and Yellow must be connected to the terminals in the plug which is marked with the letter - E - or by the earth symbol, or coloured Green or Green & Yellow.
The wire which is coloured Blue must be connected to the terminal which is marked with the letter - N - or coloured Black.
The wire which is coloured Brown must be connected to the terminal which is marked with the letter - L - or coloured Red."
"FLEXIBLE CORD WIRING LABEL
If the socket outlets in the home are not suitable for the plug supplied with this appliance it should be cut off and an appropriate three pin plug fitted.
NOTE: The plug severed from the lead must be destroyed, as a plug with bared flexible cord is hazardous if engaged in a live socket outlet.
Only use a fuse that is approved to BS1362.
The fuse rating is given in the appliance instructions. Only the rating indicated must be used.
Always replace the fuse cover. Never use the plug with the fuse cover omitted.
WARNING: THIS APPLIANCE MUST BE EARTHED.
APPROVED BY BSI LICENCE NUMBER KM 10807"
"IMPORTANT:
Blue - Neutral
Brown - Live
