I recently bought an early 80s Technics component system so I could make it easy for everyone to share music at the new office I began working at. The set included an SE-A808 amplifier, ST-K808 tuner/preamp, SH-R808 remote control and receiver, SH-8030 space dimension controller and an RS-M45 tape deck. I had to have a matching turntable, so I picked up a busted SL-Q303 turntable to fix up the next day.
We all work on MacBooks and have iPhones, so I bought an Airport Express for Airplay streaming. The office is in a former warehouse, so I think the early 80s metallic aesthetics of the set matches the industrial setting perfectly. It's been a hit and everyone is now sharing their favorite music and getting conversations going, so I'm happy.
On the SL-Q303, I repaired the loose chassis, added new feet made from PVC bushings and Vibrapods, polished the dustcover inside and out and replaced the cartridge and stylus with an Audio Technica AT90 kit.
Also, The platter mat was in bad shape and warped. I tried to bend it back into shape, which was a bad move. It tore in the center pretty badly. I didn't want to give up on it though, since finding a mat replacement for the SL-Q303 is almost impossible. I heated and pressed it, then glued it, and heated and pressed it again overnight. Now it's straight and is functional once again.
Anyhow, I got all excited about the possibility of controlling the SL-Q303 with the SH-R808 remotely, only to discover that it seems Technics only ever offered a remote control input on the SL-Q33. However, finding an SL-Q33 is almost impossible. They don't come up often on eBay in the U.S. and I can't find anything overseas.
My plan B is to source a remote control input for the SL-Q33 and modify the SL-Q303 so it can be controlled with the SH-R808. However, I was hoping someone here could help me determine whether this is feasible without the logic board from an SL-Q33.
I can find the input and order it or piece together the parts to make my own. I would just like to know -- is it possible to make this modification if I cannot source the logic board for the SL-Q33? Is it possible to send signals from the SH-R808 receiver and remote to trigger functions on the SL-Q303 through wiring?
Admittedly, I do not have experience working with electronics save for wiring and soldering, and I will be working with a local electronics technician to accomplish this. All I want to know is if it is possible to accomplish this if I don't have the board from the donor turntable.
I've included some screenshots of an SL-Q33 that someone on AudioKarma.org shared when they were restoring a turntable.
SL-Q33 Input for SH-R808:
SL-Q33 Wiring and Circuitry:
Any insight is greatly appreciated.
Thanks!
Thanks!
