Ok, so here is a pdf file presenting a power schematic of the welder. I hope it will provide us some more information about how this oscillator works. Moreover, I still have another questions left (I used to crop an image of some unknown connections to search for their topologies on Google picture search, but I still can't find my answer).
First, it starts from the "Board A". As a user hits a switch U15, 220 volt enters the board to reduce a common mode and differential mode noise. L3 and L4 are coupled inductors on the same ferrite core.
My question at this point:
1. Since C25, L3 and L4 can effectively annihilate a CM and DM noise, why they put C17,18 and 19 to do the same job twice?
2. When the U10 relay is NC, what do R35 and R36 do?
Second, we are now at the "Board B". It rectifies an AC signal.
1. However, what is the purpose of putting R37, R38 and the four capacitors paralled to them?
Third, at the board C, a 2 switch discontinuous mode flyback converter controls the amount of the welder's output voltage.
1. Why must they add components to the right of D11 and D6?
2. Could you please explain the gate driving sub-circuit? I've simulated buy putting a square wave to the node "Red2(S)-C". The result, as predicted, is just the wave-1.4V (1.4V from D2 and D4 voltage)
Fourth, at the board D, D15,16,17 rectify the welder's output current. Also, they put D18 and D14, acting as freewheeling diodes, which provide path current from the welder's load and inductors in the case that D15, 16, and 17 are turned off. C13, R30, C12 and R29 are acting as a band-pass filter.
My question:
1. Since the welder is a dc-output type welder, why do we need a band-pass filter? Are D17, 16, and 15 enough to provide dc current?
Board E:
Almost unknown about these board. Seems like a feedback system and protection system.
Board F:
It receives a signal from a signal board at Yellow(s)-F and Yellow1(S)-F and rectifies it into dc. This dc passes through an oscillator, as mentioned by steve, the output of this board, A1-A2, is sent to a transformer near board D
My questions:
1. Is this a technique for decreasing or limiting the welder's output current? (My reason is that since voltage across A1 and A2 can be controlled, we can control the amount of a TX4 secondary side voltage, allowing us to increase or the decrease amount of output voltage)
2. I do not quite familiar with this type of oscillator. Do you figure it out?
