Hi. I don't have a function generator but have a spare iPod.
I went online and downloaded some audio tone files (from 10 Hz all the way to 22000 Hz, sampled at 44 KHz).
I don't understand the -3 db on the files. I assume there is a maximum decibel limit to sound files and the files just used -3 as a setting for them (with actual amplitude based on the volume control of the output device).
What I want to do is generate waveforms to examine on my oscilloscope to learn about phase shift.
I am thinking to play the audio files on my iPod, and have the signal output (from headphone jacks cable) to a transistor Base, and amplify a 9v battery voltage across the Collector / Emitter. I read that the headphone jacks output is about 2V peak (although I haven't tested it, and I wonder whether it isn't the volume control on the iPod that determines actual voltage levels).
And furthermore, I would then use the voltage from the transistor to put through resistors and capacitors to observe phase shift.
Will this work?
One thing I am wondering is, this won't be an AC signal but a DC signal.
I don't know how I can generate an AC signal. I could rig up some magnets and coils and turn them around with a DC motor I suppose. But anyway, what about the above iPod setup?
Will this work?
