Intermittent Problem with Circuit Design. Asking for Assistance.
Jim Thompson
Perhaps I didn't draw my circuit right? I'm not the best ASCII artist.
This is what I have made (thanks to Jim Thompson for the circuit I
stole and reconfigured):
+5V o------------------o
10K
o-----> OUTPUT
Gnd---o-----|
| E
_|_ |
330pF ___ |
| 5K
-5V/0V INPUT >-o-------o
course, my original problem was that it was intermittent. All I did
was add the capacitor, and it so far has been working 100% of the time.
Any thoughts? Or should I give up and never touch any components ever
again?
Maybe you had a bad solder joint? But your above circuit does not do
what you specified originally.
As drawn above, and working properly...
-24V Input --> ~0V Output
-12V Input --> ~0V Output
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice:(480)460-2350 | |
| E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
| http://www.analog-innovations.com | 1962 |
Anyone can be rude, but it takes a Democrat to be a real dirtbag.
Derrick Tennant
Well, I left out the zener diode, just for laziness. :)
I guess this would be the exact circuit I have:
+5V o---------o
10K
o-----> +5V/0V OUTPUT
Gnd---o-----|
| E
_|_ |
330pF ___ |
| 5K
o-------o
__|__/
/ /_\ (18V)
-12V/-24V INPUT >--o
....and the way it is now, during a -12V pulse, the output is +5V, and
during a -24V pulse the output is 0V.
This works for the application, because I then run the +5 through an
inverting buffer, which would give me my required correct output.
Jim Thompson
+5V o---------o
10K
Gnd---o-----|
| E
_|_ |
330pF ___ |
| 5K
o-------o
__|__/
/ /_\ (18V)
I'd put the threshold at mid-signal... zener = ~15V.
...Jim Thompson
Rich Grise
I thought your original spec was...
-24V Input --> +5V Output
-12V Input --> 0V Output
D'oh!
Common base is non-inverting.
Yes. I got it back-asswards: Here's an excerpt of the OP:
" The kicker is that at -24VDC it needs to be converted to +5VCD, and at
-12VCD, it needs to be at ground."
You need something like this...
+5V o-------o-------o
10K 10K
| o-----> OUTPUT
o-----|
--- E
12V / \ |
| o----GND
10K
INPUT >----o
Yeah, looks OK to me, except of course, I have to futz around with
everything:
+5V o-------o---------------o
10K 10K
| o-----> OUTPUT
o-------+-----|
--- / \ E
12V / \ | |
| `-------o----GND
10K 1N914, 1N4148, etc.
INPUT >----o
Cheers!
Rich
F
Fred Bloggs
+5V o---------o
10K
Gnd---o-----|
| E
_|_ |
330pF ___ |
| 5K
o-------o
__|__/
/ /_\ (18V)
You need to watch pulling logic inputs negative. Since the application
requires no gain, a simple level level shift with over/under-voltage
protection is all that's needed:
View in a fixed-width font such as Courier.
.. +5V
.. | 74HCT14
.. -12 --- [10k] -- 5
.. | 20VZ | |\ |
.. | ---|>|--|<|---+----|>|--+---| o--- |
.. | / 1N914 1N914 | |/ |
.. -24 -- | --- 0
.. [100k]
.. gnd
K
Keith Williams
To-Email- said:
Sorry. Should have said the above plus... or you'll have very weenie
base drive ;-)
Ohh, 5V BVebo. Ouch! ...wasn't considering reality. ;-)
Maybe the common base configuration is a good idea. Thanks.
