alarman
Anyone using these? It's a glassbreak with a built-in door contact. I pulled
one out of a binky install. Any good?
alarman said:Anyone using these? It's a glassbreak with a built-in door contact. I pulled
Crash said:I've only got 8 out in the field...for abt 2 years or so...no
problems.
alarman said:How are you using them? Hi or lo sensitivity? Do they work ok mounted on the
wall above the door/window, or do they need to point toward the glass? I was
thinking resi sliding glass doors. Sentrol used to(maybe still) make a combo
unit that was real slick. Came with a bracket in case you wanted to mount
it at 90 degrees. I stopped using those because of false alarms caused by
barking dogs.
Mark said:You know you can adjust them right? They have this thing called an "FG-701
tester"
G. 'Cracker' Morgan said:They false too much on either setting, smart-ass.
Crash said:It's all in how/where you install/adjust them, for that you need a
rocket scientist.
alarman said:Ayyy-yup.
rbl is a rocket scientist alright, pocket rocket.Mark said:Well it does explain why you had so many problems with them
Satellite Of Love?Robert said:In that case you're SOL.
Joe said:Satellite Of Love?
