Brandon said:
Wondering if there is some rule of thumb for instantaneous current
limits in DC motors? I think I read somewhere that 3 times the
constant current was a good guess, but, even if that is true, that
doesn't address how long the higher current can be applied.
For AC induction motors, without brushes, the maximum current is
self-limited to about 3-5 times the rated current, and a thermal motor
controller will limit that "stall current" to about 5 seconds.
But for series wound or permanent magnet DC motors, much higher currents
can occur. You are probably safe to use a circuit breaker or fuse rated at
the normal current value, although a slow blow fuse or a time delay circuit
breaker could allow 3x current for as long as 60-90 seconds, which may be
too much.
If a motor has an overload spec, you might be able to use that for an I^2t
rating. So a motor that is rated at 10 amps, and can run at 20 amps for 10
seconds, has an I^2t of 4000. So you can run 32 amps for 4 seconds, and 63
amps for 1 second. You must also allow a cooling off period between bursts,
and this is also a square law function. At 2x the duty cycle,
ton/(ton+toff), is 1/2^2 = 25%, at 3x it is about 10%, and 5x it is 4%.
But the brushes might limit the safe overload to a lower value. At some
point there will be excessive arcing and localized heating which could
cause damage and reduced life of the brushes and commutator. These figures
are related to I^2R heating effects, and are commonly applied to
transformers.
Brushless DC motors have their own limitations due to the solid state
components, and should have overcurrent protection built into the
controller.
BTW, there is no such thing as a DC motor. It must be converted to AC by
some means to make it continue to run. The only true DC machine is a
solenoid. There is also no such thing as DC. The current had to start at
zero at some point in time, and then it took a finite time to reach some
level, and eventually it will return to zero. So it's really a rectangular
waveform of (perhaps very long) period.
Paul
