John said:
It isn't dubious, and the application is not radio. There is strong
evidence for the increase in intelligibility, but one particular piece
of work is unpublished for commercial reasons.
I realize it is not radio (and that's actually why my doubt of the application
exists). However, much of the work on articulation index and speech
intelligibility has occurred in the radio/telecom field. More specifically,
radio/telecom work has dealt quite directly with the concept of speech
clippers--probably more so than other fields since it tends to be a distinctly
peak power limited environment (especially radio). It is a source of info
so-to-speak. That is, the effects of clipping on speech intelligibility has
been dealt with directly.
For all my references, clipping does not *increase* intelligibility. On the
other hand it does *not harm* the intelligibility for rather high peak clipping
levels (up to 20 dB or so). It does however degrade the subjective quality.
Again, this is according to my sources. One of which is (ch2):
http://www.noblepub.com/shopexd.asp?id=11
I think the discussion in it is pretty good. "RF/IF clippers" are the best.
I would naturally be interested in technical discussion and evidence to the
contrary.
http://www.dstan.mod.uk/data/00/025/16000100.pdf
(6.1.3.17 Peak Clipping with Noise
"If the speech is clipped before the noise mixes with it there can be
an improvement in intelligibility." Of course, that is exactly the _radio_
problem solved.
6.1.4.10 Peak Clipping
"Peak clipping can improve intelligibility of a relatively noise-free speech
signal from
a microphone, in situations where high levels of noise mix with the speech
before it
reaches the listener. The clipping must occur before the noise mixes.
Although peak clipping the audio waveform can improve intelligibility, a better
approach is to use Radio Frequency clipping. With AF clipping the distortion
products are spread throughout the speech band.
When the RF waveform is clipped, the distortion products do not overlap the
transposed speech frequencies, and can be filtered out before the RF signal is
transposed back. [Not generally true as I pointed out earlier. Harmonics are
gone, but not odd-order intermod products.] The final audio waveform has
smoothly rounded peaks rather than
flattened peaks." [True])
bucketloads of free-bee's on speech/hearing:
http://www.vard.org/prog/98/98prch13.htm
"In backgrounds of noise, both intelligibility and quality were more adversely
affected by peak clipping than by compression or linear amplification. ... These
results indicated that the output of a hearing aid should be limited with
compression rather than peak clipping."
http://www.kemt.fei.tuke.sk/Predmety/KEMT320_EA/_web/Online_Course_on_Acoustics/intelligibility.html
http://www.jblpro.com/pub/technote/spch_intl_1.pdf
http://www.jblpro.com/pub/technote/spch_intl_2.pdf
http://www.icsi.berkeley.edu/~steveng/PDF/Spectral_Slits.pdf
http://www.icsi.berkeley.edu/~steveng/PDF/Bandshift.pdf
http://www.icsi.berkeley.edu/ftp/global/pub/speech/papers/icassp98-uttcomb.pdf
http://www.wramc.amedd.army.mil/departments/aasc/avlab/Eurospeech2003-R.pdf
http://soma.crl.mcmaster.ca/~jeff/NIPS/NIPS_Submission.pdf
http://www.gold-line.com/pdf/articles/p_sti01e14.pdf
http://www.icsi.berkeley.edu/ftp/global/pub/speech/papers/thesis-bedk98.pdf
http://www.phonak.com/com_1998proceedings_6.pdf
http://www.phonak.com/com_1998proceedings_9.pdf
http://www.acoustics-engineering.com/files/TN002.pdf
http://www.svconline.com/mag/avinstall_measuring_intelligibility/
http://fonsg3.let.uva.nl/Proceedings/Proceedings20/ShuzhenWu/ShuzhenWu.html#Heading6
http://www.frye.com/library/acrobat/hrarticle.pdf
http://www.frye.com/library/acrobat/hrarticle2.pdf
http://www.auditory.org/mhonarc/2002/msg00326.html
http://www.cnel.ufl.edu/~markskow/papers/mdsThesisMain.pdf
http://ieeexplore.ieee.org/iel5/8159/23791/01091628.pdf
http://www.eng.uwo.ca/people/vparsa/Audiology/Compression_Tutorial.pdf
"It also seems to be established that compression limiting gives superior
quality to peak
clipping, although the hearing aid needs to be sufficiently saturated for this
advantage to occur
and it is not known how often this degree of saturation occurs in practice for
various degrees of
hearing loss and for various maximum power output settings. There appears,
however, to be no
reason not to use output controlled compression limiting over peak clipping,
except for the most
profoundly impaired listeners."
