Installation of OutBack System: first impressions
Steve Spence
Having not used a beacon, I can't comment on it's usefulness, or lack
thereof. However, even if something doesn't have all the bells and
whistles that some consider "a serious off grid system", but still
allows one to live off grid, then it just may be appropriate in some
instances. Our AC DELCO inverter is a msw, non-stackable, chargerless,
no transfer switch enabled model, and compares miserably to a xantrex sw
or a outback, but at $269 for a 2500 watt unit, was appropriate for us.
We have a "serious" off grid system. If it fails, it's a serious problem.
I would like an outback, but my budget won't allow it.
Steve Spence
Dir., Green Trust
http://www.green-trust.org
Contributing Editor
http://www.off-grid.net
http://www.rebelwolf.com/essn.html
G
Gymmie Bob
Alwaya flame and never any answers in this group. When did the nursery get
out?
Most conclude their isn't many knowledgeable people here. I do. Most are in
my bozo bin now but there are still a few more to go.
G
Gymmie Bob
If you guys knew what you were talking about you would be dangerous.
Beacon Power's system is on-grid/ off-grid and MPPT are rolled into one. It
PP tracks much better than the Xantrex and other known brands on the market.
Funny how the ignorance shows by the amount of aggresion to any idea here.
Fucking children.
Robert Morein
What's the fuel consumption at zero load?
Bruce in Alaska said:
Nothing like a Northern Lights Lugger Diesel. I got a pair of the 20Kw
units and they are one serious genset. I saw a rebuilt one on ebay that
went for less than $1500US a few days ago, and there is another there
now, that started out at $1500US with less than 1000 hours, and that is
just barely broken-in, for a Northern Lights.
Bruce in alaska
G
Gymmie Bob
Once again you are an ignorant asshole disguising your lack of confidence.
Do your own research asshole. Advanced Energy never produced an M5. Come
back when you can carry on a converstion like a grown up
<PLONK>
Derek Broughton
I had something of the sort (can't actually remember the brand, anymore)
before the Outback. Then, one foggy week, I had to turn on the generator -
and forgot to unplug the inverter first - and fried the inverter. I'd have
to do that three more times before the Outback pays for itself, but I think
the odds on that were pretty good :) It gave me two years of solid
modified-sine-wave service, though. I can't help but wonder if there isn't
a market for a cheaper version of the Outback without all those bells and
whistles - or whether the features add so little cost that without them
they wouldn't sell for much less.
Bruce in Alaska
I have no idea, because I load it up and use it EVERY Day....that's why
I have it, as I generate ALL my own power.
Bruce in alasla
Robert Morein
Me said:
Call them and ask them......
Me
and believe them?
I've always wanted a big diesel. The problem is inefficiency at < 50% load.
Me
Robert Morein said:
and believe them?
Wrong, Low Rpm Diesel gensets are very linear in fuel vs load once you
get passed the 25% load range.
Me
Robert Morein
[snip]
Me
That's very interesting.
I would like to hear it from multiple sources.
There's also the problem of engine damage -- glazing, carbon accumulation.
I wonder if there are known prescriptions for managing this with lightly
loaded diesels.
Me
loaded diesels.
Yea, and your the same Dufus, that wants everything in Triplicate
too.....
Me
Robert Morein
too.....
Me,
That's gratuitous.
Let's keep the group clean.
Bob Morein
W
Windsun
How about we keep the crap and non relevant infantile remarks out of here?
daestrom
Robert Morein said:
[snip]
Me
loaded diesels.
Those are good points. It *is* true that fuel consumption in a diesel is
very linear with load (for a constant RPM). This is because although it is
always moving about the same amount of air through the engine, the pumping
power to move that air at partial loads is *not* the same as for an Otto
cycle (diesel has almost no differential pressure from intake to exhaust,
while Otto engines at part load go from 20+inhg vacumn to atmospheric).
The large engines I've seen used for emergency power were very good about
fuel use at part load. But they *do* soot up at part load and that can be a
problem. The big units with turbo-charged two-cycle engines also had issues
with the gear drive used to drive the turbo at low loads (EMD's for
example).
But the fix is pretty painless unless it gets real bad, just load up in a
few incremental steps to 100% and run for ~hour there to 'burn' it off.
Mind you, that only applies to the carbon deposits.
As you probably know, there is only one fix for glazed cylinders though,
tear down and hone the cylinder wall. :-(
Interestingly, the EMD's used in railroad locomotives are almost exactly the
same as those used for standby power in many applications. But because they
are run at very low RPM when unloaded, they don't have as much trouble with
idling for long periods. Too bad a standby generator can't 'idle' at 200
RPM :)
daestrom
Scott Willing
Ah yes, "Me" doesn't seem to have noticed that this group is (usually)
a cut above the typical pointless usenet slug-fest.
-=s
Robert Morein
daestrom said:
Robert Morein said:
[snip]
Me
loaded diesels.
example).
Is glazing inevitable, or is there a prevention?
Me
Robert Morein said:
daestrom said:
Robert Morein said:
[snip]
Me
loaded diesels.
example).
The prevention is to run the engine at 75%+ load at least 5% of the time.
This will cause the engine to reach heat equilibrium, burn off any carbon
buildup in the cylinder, and allow the cylinder/ring interface friction
to reduce any glazing component.
Me
