Hello
I've been trying a diferential output amplifier, as it is my intention in the future to build a transistor oscilloscope, with better performance that the valve one that I'm currently using. Althought the circuit that I've been testing amplifies the input signal very well, it suffers from instability with no signal applied.
That means that with the input connected to ground, the voltage across points A and B (see picture) is constantly "moving". The range in which it moves, is about 0,6V. Then the trace on the scope will be moving too.
Voltage at points C and D, are very stable, and Vcc (60V) is also very stable. So I can not find tha reason for this instability.
I'm asking for help to solve such instability.
Thanks in advance
Thanks in advance
