N_Cook
Been asked to repair this , if possible, unlikely, but I will at least look.
DLP type.
Never looked in a projection TV before, currently red LED falshing ,
supposed to indicate blown bulb. No light at all on switch on .
Prior to that , not seen by me , only reported, there was a slightly
diagonal shadow across the very right hand edge of the screen, but still
being used like that.
Only 2 wires to the bulb , is it filament type ? if so open circuit, but no
obvious blackening or anything.
The whole inside is covered in dust, including a very dusty reflector on the
bulb. Would it be safe to blow out the dust, from the whole iside of the
casing, with a 1KW blower or is there anything like the rotating filters
likely to be dislodged or damaged.?
DLP type.
