V
v man
I have a small 12V DC off-the-shelf circuit that operates a few 240V AC
relays. The circuit is controlled by a PC via a parallel port.
It works OK with no load, no problem there.
However, when I manually unplug any of the devices connected to the relays
(they are neon and halogen lamps) somehow the circuit board gets all screwed
up and switches on (or off) the relays at random. Even worse, it also
happens when the board itself switches the relays off. When there is no
load connected to the relays everything works 100%.
I suspected that it might be the "inductive kickback" problem, so I
connected 0.1uF caps snubber across each load terminal. It did not help
unfortunately. I also tried powering the circuit board from a power point
in a different room, no change.
Is there anything else I can try? I think maybe the caps are not of the
correct value, but I was not able to find any accurate info on that. The
mains are 50Hz, 240V the load is variable, up to 2A.
Thank you for any kind of help.
Peter
Peter
