Phil Allison
"Trevor Wilson"
** Weeeeellllll - that is what I am asking you to try !!!
** That is the whole point.
The nature of the "coil" is much the same over a wide range of resistance
values.
As is the turn to turn capacitance.
** No it isn't.
** You have not tried to do it and are still making silly assumptions.
Read my other posts in this thread.
..... Phil
**I said: INDUCTIVE REACTANCE.
**I've done so on many occasions. Though, I hasten to add, not 820 Ohm
resistors.
Usually, much lower value resistors.
values.
The principle is the same however.
** No it isn't.
I don't see the point in trying to measure inductance directly. As you
have already stated, the resistance value will completely swap the
inductive reactance value. With rudimentary test equipment, it is simple
enough to measure the total reactance and perform the appropriate maths to
calculate inductance.
..... Phil
