Increasing output of fixed V-Reg
davenn
hey Gang
need to increase the output of a +12V reg (7812) to ~ 13V
Is there any real hassle just using a resistor in the GND lead to the 0V rail ... ie. lifting that pin above 0V ?
rather than the more common arrangement of 2 resistors... one from output to GND pin and another from GND pin to 0V rail
have seen both arrangements in various www sites
It seems to work well with just the 1 resistor... a 220 Ohm gives me 13.2V output
Dave
The current in the tail of the regulator is not defined so a resistor can not be specified. A voltage divider with a larger current than in the tail can be set better.
Your example indicates about 5mA tail curent. I have found a similar value with a 7805 regulator.
A couple of forward biased diodes will give about 1.2V extra.
The LM317T has a very low tail current and so a resistor will not work.
The diodes should be connected in the lead which goes to ground and should be forward biassed. Each diode will drop about 0.6V. If you need more voltage than this, you may be able to find a suitable Zener diode.
I recently wanted more than 5V to drive a transistor radio and used a red led with a 7805. This had the advantage of being pretty.
CDRIVE
Dave, I've been inserting a diode or two in the GND lead of fixed regulators (as Duke described ) for years with no problems.
Chris
davenn
Chris
OK :)
diode arrow pointing towards GND ( 0V rail) or towards the reg GND pin ?
Im assuming towards GND 0V rail
Dave
CDRIVE
OK :)
Dave
Yes, like that. Cathode connected to circuit GND and the Anode connected to regulator GND pin.
Chris
