So what is the actual value? Measured.correct, I'd wrongly assume that 0.69 is the result deducted from main source.
Makes no sens. Again, show us the circuit diagram so we can understand what you are doing.FYI, I'd need to cascade with three pnp transistor to form as darlington stage to be able to produce the 340 mA (as ready measured) before it could be able to drive the motor.
Also make sure you haven't swapped emitter and collector in the actual circuit.. When you swap emitter and collector, the transistor may seemingly work but with much lower current gain.
