But as R. Baer wrote, inquiring minds would like to know...just what
sort of load are you wanting to put these pulses through, and what
amplitude current versus time are you wanting to achieve?
I guess I would be good if I actually explained what I was trying to
do.
At the very basic level what I want is sort of compact electric motor
that gives me oscillatory linear motion and can run on a small bank of
batteries for about an hour. What I need is about 3mm of travel, a
frequency of that is tunable from about 50-200 Hz (just about any
waveform will do), and "decent" force. I can't tell you how much force
I need yet because I don't know for sure, but to give you a qualitative
description I would say that the force needs to be enough that you
couldn't stop the machine with your hand and maybe if you put a pin on
the end of the oscillating shaft then the force should probably be
enough to repeated puncture heavy card stock paper. I don't know if
that's a useful description or not. Sorry I don't have more specific
information, but I'm just starting this project and I'm trying to
assess my options before I go about trying to put anything together.
The simplest idea would just be to use a DC motor and convert the
rotary motion to linear motion with a cam or whatever. I still wanted
to look at other options, so I started to think about linear motors and
also just using an electromagnet to vibrate a spring loaded shaft (i.e.
by repeatedly pushing it away). I don't know anything about linear
motors and not a whole lot about electromagnets either, but given that
I want the battery pack to be both small (a 2 or 3 cubic inches max)
and last for a long time (and note be too expensive) I'm guessing I
wouldn't have a lot of current to work with. So anyways, I was trying
to think about ways to maximize the force I got out of that setup.
Quite possibly I don't know what the heck I am talking about. I'm just
brainstorming here. If you have any ideas I'd love to hear them, but
at this point I don't have anymore information to give you.
