I have central heating throughout our boat, but it's never before been used to supply domestic hot water for showers etc. We've previously used mains (shore power) water heating with an immersion heater. Having just replaced our solid fuel heater with a bigger better model we now have sufficient heat to supply our domestic requirements. I do though, have a bit of a problem.
Because solid fuel is not as controllable as say gas or electric heating, the output from the back boiler will always fluctuate. Because of this I fitted a zone valve into the hot water pipe from the stove to the hot water cylinder. The plan was for the zone valve to open at 45-50 centigrade and stay open until the fire cools below the set temperature. This is important because the immersion heater is still used, but cuts out just below the zone valve temperature setting. I don't want a situation where if the stove is off I'm inadvertantly using the immersion heater to warm the boat!
So to condense all that I would like your thoughts on a simple but automatic on/off pipe switch that will come on and open the zone valve at 45-50C and stay on until the pipe temperature drops below that setting.
Many thanks in advance, Stu
