I'm looking for a cheap cpu module with dual serial port and an ethernet port
Rune Christensen
Hello
port.
The cpu module must have some sort of flash and ram.
I'm going to build a customize serial to ethernet converter.
The price should be below $50
Cheers
Rune Christensen
Rolavine
Subject: I'm looking for a cheap cpu module with dual serial port and an
ethernet port
From: "Rune Christensen" rune.christensen@adslhome.dk
Date: 8/22/2004 8:11 AM Pacific Daylight Time
Message-id: <4128b7ab00265$edfadb0f@dread12.news.tele.dk>
Hello
port.
Cheers
Rune Christensen
Check out Rabbit Semiconductor Modules (Digi Key), in quantity they may be
close to your target price.
Roger Hamlett
Rune Christensen said:
Hello
port.
Cheers
Rune Christensen
I don't think you will find anything 'off the shelf', at this sort of
price break, with the features you want. However you could go DIY, with
something like a PIC (one of the newer versions with two serial ports),
and a Realtek 8019 ethernet chip. Add a couple of RS232 transceivers, and
all the required features are present.
Best Wishes
Richard
port and an ethernet port.
Very unlikely.
A Rabbit 2200 module may come close in price, but by the time you add an
enclosure and supporting power and RS-232 level shifters, etc. you'll be
over your budget.
Check out http://www.picoweb.net for a cheap 1-port model. You can
build your own or license his source cheaply. If it's worth your effort
you can modify the design to add a second port.
You may get more answers in comp.arch.embedded
V
Vincent Himpe
Hello
port.
Cheers
Rune Christensen
Check out Atmel demo kit on digikeys website. they have a module called
wiznet . already does what you want ( comes with software ) sits around 30
$. ready assembled. all you need to add is ethernet connector. It supports
HTTP , SNMP and Telnet.
Bob Smith
port.
The Linksys WRT54G might meet your needs. It has Ethernet,
a four port hub, 802.11G, two serial ports (but no connectors),
and something like 16/32 MB of Flash/RAM. They are easy to
hack and there's lots documentation available. I see them on
sale for $50 every once in awhile.
Brian Murtha
Hello
port.
Cheers
Rune Christensen
Z-World/Rabbit Semiconductor has CPU core modules with ethernet as low
as 32inquantity.Devkitsstartat32 in quantity. Dev kits start at 239 and include a royalty-free
full TCP/IP stack with source and extensive protocol support, a full
version of the Dynamic C compiler, extensive sample programs including
serial-to-Ethernet conversion sample applications.
http://www.rabbitsemiconductor.com/products/rcm3700/
Frithiof Andreas Jensen
Maybe a VIA EPIA 5000 series card? Way overkill, but if it is a one-off or a
few-off ....???
