Wow okay, so for a basic parts list, I'd need what? Sorry for the constant questions
If you are after a hovercraft, I would suggest brushed DC motors. (two wires... + and -) Buy them in pairs and operate half of the motors in the opposite direction as the others so the craft won't spin.
How far you want to build from scratch is up to you... if you want to go right down to the components, I would suggest getting a 555 timer and look at some example circuits to turn it into a PWM controller. You can then turn a potentiometer up or down to adjust the speed of the motors.
Run the motors in parallel, and hopefully build it so most of the mass is below the fans to help keep it upright. You may also experiment with ducting on the fans to help direct the airflow directly downward. (This also helps to increase airflow)
So... parts for a hovering craft. Simple, no feed-back, will require some fine-tuning to get a good stable height.
- Brushed DC Motors (In pairs). At least one pair. Paired Clockwise, and Counterclockwise motion required.
- Propellers. One for each motor, of course, Clockwise and Counterclockwise pairs to match the motors.
- Power source. Most likely battery. Lithium types for Remote Control planes/cars are lighter and can deliver more power than AA batteries. The choice is yours depending on flight time, and how much lift your fans make.
- On/Off switch.
- PWM Controller. (One should be fine if all motors are connected in parallel.
- Misc. parts to build the body.
That's where I would start, but be warned this will only hover if you put the time to experiment into it... I can't give you part numbers to buy that will make a hovering craft.
