You are walking into a world of fun tiny wires, a large handful of different flight controllers, radio transmitters/receiver combos, motor controllers, and an assortment of firmware that can be installed on the flight/motor controllers.
What kind of drone are you looking to build, and what kind of experience do you have with them thus far?
Here's a small check-list for you
Drone Type : Race or Photography drone.
Drone Size : From corner to corner.
- First Person Camera Capable?
Budget :
Would you be happy with pre-made drones or pre-made assemblies or are you looking to build something completely from the ground up?
Mostly ready to fly :
http://www.banggood.com/Eachine-Wiz...8CH-200MW-VTX-ARF-p-1085802.html?rmmds=search
If you are building from the ground up... Here is a parts list.
- Radio Transmitter
- Radio Receiver (Try to find a bundle with the transmitter)
- Flight Controller
- ESC (Multi ESC units available... ie, 4x ESC on a single board. One needed for each brushless motor)
- Motors . Two Clockwise rotation and two Counter-clockwise
- Battery
- Charger
- Frame
- Misc. accessories. heat-shrink tubing, battery terminals, velcro strap, tape
- Camera (Optional. GoPro and HD cameras required for film, NTSC/PAL low resolution required for racing)
- Video transmitter (Optional)
- Video receiver (Optional)
- Video display (Optional, small monitor or HUD)
I'm working on a medium sized 250mm drone and am being blind-sided finding all the little things I am forgetting. My flight controller needs a 5V source, although the rest of my components can operate directly from the battery. The flight controller I have is based on a Naze32 controller but is a clone with limited compatibility with the tools for Naze controllers. I've rebuilt my drone 3 times so far trying to fit the components in nicely as the parts arrive and I still need to sit down and solder various wiring pig-tails together to connect the various components to each other because nothing aside from the flight controller and radio receiver seem to be capable of plugging into each other.
If you have the patients, certainly build it from the ground up. I don't suggest building your own flight controller. Buy a 'common' controller that has lots of support and ensure that it supports something like cleanflight or baseflight as you can find support for it in lots of locations.
You have to let us know exactly what you want to try to do. Asking generic questions about how a specific part of a drone won't get you the information you need... As I covered in my last post, we could have replied with a very generic 'push the left thumb-stick forward' or we could answer with a detailed explanation about how the radio receiver may send a PPM or PWM signal to a flight controller which does some math and calculations before sending a PWM signal to a motor controller with will vary the rate and power being delivered to a 3-phase brushless motor...
If we don't know, we either assume and waste time or some of us will make silly comments.
Give my post a good read or two and decide which path you want to take, and we can do our best to guide you in the part selection, product selection, or planning stages if you want to build from the ground-up. Just be warned that building a flight controller may be an overwhelming task for a beginner.
