It should be possible to restore discoloured LCD panels by replacing the polarizers (front/rear) - indeed I have successfully changed reflective displays (with no backlight) into backlit "transflective" displays by replacing the opaque rear polarizer with one which lets (some) light through. But when I recently tried to restore the sun-burnt LCD in another VDO Logic series instrument (the "
Multifunction" NMEA data instrument) the display came out looking very yellow, and the text which had previously been black had turned blue. I would be interested to hear if anyone here on the forum has any idea what may have caused this?
I had assumed, without testing, that the polarizers were horizontal & vertical, so that's how I fitted the new ones. But after seeing the result I removed them, suspecting I got the orientation wrong, and compared them with the original films (I should have done this first, of course). I found that the original polarizers were indeed oriented at +/- ~45 degree angles so (although they were now ruined by fingerprints & dust) I tried to find a better combination of angles with the new films. But although I was able to get rid of the ghosting around the inactive segments, I could not eliminate the strong colour cast, only change it from yellow to an orangey-red. So my problem doesn't
seem to be linked to the orientation of the polarizers.
I found something interesting when comparing old vs new though; the old front polarizer appears to be made up of two layers, one of which had partially peeled during the (somewhat violent) removal. When combined with a piece of the old rear polarizer on the back of the glass, the part of the front polarizer which still has this second layer looks normal - but the part where it's missing exhibits the same colour cast I got with the new films. Conversely, in negative mode the dual layer part shows as black while the single layer portion is blue.
What might this second layer be? Do I need a different type of front polarizer film to get rid of the colour cast?
Edit: It is worth noting that the new films show no sign of any colour cast when looked at without the LCD glass panel in between them. In fact, when compared side by side with the original front polarizer it is impossible to tell new from old - the transmitted light looks 100% identical and neutral.
