Sir endruw. . . . . . .
Say Whaaaaaaaaat . . . . Do you mean that this is what I would find inside one of those . . .
small . . . hardly more than a few cubic inch square SNOW WHITE Apple chargers ; SHOULD a person initially, even be able to NON-DESTRUCTIVELY . . . extract its mini PCB from within?
If you blow / clean off some of the white faery dust from the board, other markings might further show up, BUT I can now readily see the . . . cramped for space . . . placed aside markings of U2 AND D8 which would definitely make your mystery unit a diode.
Now . . . U2 we know as a 3 terminal integrated circuit, in this case a TL431, which we recognize as being an ADJUSTABLE “ zener in a chip”.
NOW . . . . . pull out ye olde DVM and place it in diode test mode function and try its probes across the two terminals of that diode in the charger units, in a no power applied status.
In the testing it should show up as dead shorted----open circuited---- or its forward junction voltage . . .Vf . . . should read out in one of the two test connection modes (Applied test leads polarity swapped.)
By virtue of its close circuit proximity to the TL431 . . . I do not tend to suspect a Zener diode.
Coming back with that good Vf reading should at least confirm if it’s being a conventional diode, with an ~ 600—700 millivolts range OR if it is being down in the 400mv range, you may have a fast switching characteristics unit, OR lastly, a Vf being in the high 100----200’s of mvs, relates to its being a Schottky diode.
( Whoooops I guess that I don’t be having too much smarts . . . as spel chex iz dun tellin’ me now, that it shud bees a SCOTTY diode.. . . . . HAH . . . a lot they noes ! )
At any rate, getting a valid Vf reading should substantiate that it’s basically
NOT being a suspect / bad part.
Matter of fact . . . in referring to my provided schematic of the evolution of those Apple units, we can see the same electronics assigned D8 designator even being used there.
Even then, it retained the same D8 assigned designation.
Referring to my provided schematic,
YELLOW box, we see Vcc output voltage being basically applied to R13/R28 used as a sampling voltage divider bridge to establish the Zener voltage set up in the TL431.
AND THEN, we also have a like divider set up at R35/R8 to the right, but with a temp sensitive thermistor R35 in the top leg.
In temp sensing, the D8 steering / isolation diode then permits the conducting in / insertion of a correcting voltage to override the other settings initial reference voltage.
TTL431’s drive voltage in the optical isolator to its internal LED modifies the isolated phototransistor for its correction of the other dynamic power supply section of the unit.
Now, tell us your reading of the Vf spec of your boards D8 diode unit.
RELEVANT APPLE CHARGER SCHEMA
73’s De Edd
