Hello everybody,
I'm trying to realize a bridge I2C - SPI with a board that carries a PSoC 5LP. The board receives I2C packets from another board with Linux inside (commands like i2cset and i2cget) and converts them to SPI format towards a board with a camera sensor. The first board is a I2C master and the sensor is an SPI slave, so the PSoC implements an I2C slave and an SPI master.
The problem I am facing with is that I don't understand how to correctly detect, in the PSoC, that I have received a get or a a set instruction. It doesn't seem to exist any interrupt callback that signal that event; there are some flags, though, that are set in a odd way and, it seems, not constant sequence. Due to this behaviour and because I check these status flags to detect the sets and gets, sometimes after a get instruction (correctly detected) it also catch a get instruction, thus performing an undesidered write on SPI.
The pseudo code is the following:
while(1)
if(write status flags are set)
do spi write
else if(read status flags are set)
do spi read
copy data to i2c buffer
Does anyone know how to correctly detect the i2c packets? I'm using PSoC Creator 4.1 as IDE.
Thank you
while(1)
do spi write
do spi read
Thank you
