Hello there
I want to made a mini portable heather for a
36.8v 8.62A 320w solar panel I have just purchasse.
I have cut and mached a 120v 1500w heather resistance wire to get a 4.23 Ohm and all seem to work perfecly on direct connection to my solar panel.
The cable come red and not over heathing.
Also I have take off the oldy Ac 120v motor fan witch is tranfo and have replaced it witch a 12v 0.17A PC fan.
The probleme is that the DC motor work only on 12v.
My question is :
1. it is possible to connect the dc 12v fan in serie witch the heating résistance to lower is 36.8v to a more apceptable 12v voltage.
Also the AC thermostac of the Heather seem to not like the 38.6v DC voltage and have stopped working after 2 minute. why ? and is there spécifique thermostat for Dc voltage ?
Also I want to try to test some of my projets in to Yenka the free electronic simulator But I C'ant figure out how to simulate any fixed amperage in to yanka ? as the ampérage is not regulated ? (I have try to put a constant courant device but not working as the courant is dinamic)
Thank for your help.
My question is :
