Is th eintermittent operation linked to anything you do with the equipment, e.g. when you move the connecting cable or the unit? Intermittent operation is often caused by a bad connection or solder joint. A visual inspection plus tapping against any suspect connections may reveal the culprit. Repair should then be obvious. Open the unit and check internal connections, too, including solder joints on the PCB(s).
Unfortunately there is probably not much more you can do yourself.
Not me, sorry.
