I can't get power to this vacuum pump
hi, i'm new to the electronics game and this forum so everybody bear with me for a minute. i just purchased a vacuum pump from an online industrial vendor, now the power supply doesn't have a regular 120v house outlet but has a 4 pin adapter. I am not even in entry level in electronics and have no idea how to convert the 4 pin adapter so that i can plug it in to a wall outlet. the 4 pin colors are 2 black one brown and one blue. if you could help in any way thanks sooo much and if not thanks again.
Contact the vendor, and ask them.
Didn't you get an instruction sheet when you made the purchase?
The vendor or the manufacturer will be able to give you the information you need.
If you don't do any of that. Tell us the manufacturer and model number of your pump,
and somebody here will probably find the information for you on-line (or you can do it
yourself).
People here like to help. But when you ask a question like this, you need to give
us the information you have. Manufacturer and model number of the pump.
Thanks for responding. The item in question is a Thomas 2505CE38 45-985 Compressor and Vacuum Pump. I purchased this item because in the description it states that it can pull up to 27" Hg and that's ideal for vacuum infusions for fiberglass, which is the project I am currently on. But again the only power source it has coming from the motor is a 4 pin adapter, with 2 black one brown and one white wire. If anyone can help in any way it is much appreciated, as of now the project's on hold until I do more research.
I used Thomas pump/compressors in industrial pneumatic valve applications.
They're great.
They also have excellent product support with parts and spec sheets.
Resqueline gave you the info you need. If you need more help, Thomas can give
it to you.
You made a good choice there. Thomas is one of the best.
Man, having this much help really means a lot to a DIY'er like me. I'm only 26 but I have a passion to create and to invent, and the work never stops. I will continue my research and will keep you guys posted on my progress. Thanks again for shedding a little more light on the subject.
Okay I am about to place an order online for my 30uF capacitor, but what do I need to do with the capacitor in order to run it to a home outlet?
The two terminals on the capacitor will be connected to the two black wires. The blue wire will be connected to the power Neutral. The brown wire will be connected through a switch to the power Hot. A green wire should be connected from the motor case to power Ground. In the US, power cords are black=Hot, white=Neutral, green=Ground
Ken
i just went to the shed and remembered i have an old tv with tons of capacitors. so there's this one that says 100uF 200v AC. the sticker on the motor says 115v. this capacitor will i have will work right?
No! The capacitor you need is 30uF. This is not a filter capacitor , where more is better. It's for phase shifting, so the value is important. The voltage in an inductive load can peak higher than you line voltage. Go with the 30uF/370VAC one.
Ken
