Friends I am making a circuit in which I need such a functionality, when i press a push button(to give 5V high pulse), it continuously turn ON the LED (even i release the push button). and to turn OFF that LED, i push another push button.
Someone told me to use an IC (BT137). This IC has 3 pins T1, T2 and G. when i give the high pulse(with the help of push button) at 'G', it short circuit T1 and T2. i use T2 as input(5V) and T1 as output. i connected the LED between T1 and ground. To turn OFF LED i short circuit T1 and T2. But this circuit is not working.
I need this circuit urgently. can anyone help me please... i will be thankful to u.
LED glows as long as i press the push button, as i release the push button it (LED) turn off. but i need, when i pres the push button it continuously glows.
the IC which I used is BT137 600E.
can anyone send me circuit diagram (with component values ) for this task?
I will be very thankful to you...
