Need help with making a circuit for a peltier module
To heat or to cool?
Either way you need a constant current source where the current chosen is representative of the temperature produced - which itself will be a product of the peltier and the heatsinking attached.
To heat or to cool?
Hi there, im gonna be using 2 peltiers, one to heat and one to cool
Why such a Low Voltage Peltier?
3.8 Volts?
All the ones I use are rated nominal 14.4 volts.
As needed for Automotive applications.
Heating verses cooling, Just reverse the polarity.
But what is your application?
Yes regulating the Temperature is Good, Especially Important on the HOT Side.
3.8 Volts?
These are just the ones ive been given, i honestly just need to get it working with a push button so it will heat up/ cool when button is pressed. and stay at a constant temperature
For Constant Temperature, Would require a Temperature Monitoring Probe and Current Control Circuits.
NOT EASY with your Proposed Push Button Control.
What is your Power Source?
well constant isnt required, but ideally dont want it so hot it would burn you if touched. But power source im not sure about, i saw a thing about using arduino for setting up peltier but comments said it wont supply enough current. Really i need a circuit design i can just follow
hevans1944
Hop - AC8NS
You really need to define what you are trying to DO first before seeking a circuit design.
A Peltier device moves heat from one surface to the opposite surface, the direction of heat flow depending on the polarity of the current applied to the Peltier device. If you are trying to control the temperature of one of those surfaces, the other surface needs to be attached to a heat sink that can absorb heat from the first surface, or provide heat from ambient environment to the first surface, either way depending on Pelitier heat-pumping action, which will depend on whether the first surface temperature to be regulated is higher or lower than ambient temperature.
So, presuming you have a Peltier device connected to a "black box" with incoming power and push button on it, what do you expect to happen when you push the button?
Pretty much im integrating this with haptics for VR. So the user will be touching the peltier to feel the heat or cold while in the VR world. So really i just need the peltier to heat up/ cool and for the user to be able to touch it
hevans1944
Hop - AC8NS
That simplifies things a lot. You can just run the Peltier "open loop" without any temperature control, choosing a current for heating and another current for cooling. The efficiency of the Peltier is different, depending on which way the heat is flowing, so you will need to determine the two currents by experiment. Since this is part of a VR presentation, you should integrate a touch sensor with the Peltier device so the Peltier device IS the pushbutton.
The circuit for changing the direction of heat flow can be as simple as a DPDT relay: actuated it applies power to the Peltier device in a direction that causes the touch surface to heat; de-actuated it applies power in a direction that causes the touch surface to cool. A second relay can be used to turn power on and off if desired. An Arduino, or similar microcontroller/micorprocessor, can be easily programmed to turn on and off a MOSFET with logic-level gate actuation for pulse-width modulation of the current supplied to the Peltier device. Setting the duty-cycle in the PWM software routine to zero effectively turns the Peltier device off. Then you choose two other duty-cycles for heating and cooling by trial-and-error, remembering to associate the actuation/de-actuation of the heating/cooling relay with the appropriate duty-cycle. You can also use an H-bridge configuration (Google this) to control the heating direction as well as produce the PWM of the Peltier current.
Many ways to build a touch sensor integrated with the Peltier device, but that is a separate problem. You might consider capacitance-sensing circuits (there are integrated circuits available for this function) as well as membrane switches.
Do you have any experience with electrical or electronics circuits and the construction of same? Do you seek a "monkey see, monkey do" solution, such as you might find in an Instructables project?
I have a little experience but mainly I specialise in software development hence the VR aspect of this. So ideally a simple solution would be perfect, or a circuit diagram i can follow in doing this.
What are you intending to use as a Power Source for this?
Battery or power adapter.
That Module is 3.8 volts, somewhat an odd rating for either of these sources..
Want to talk, the UK is a free phone call for me.
For Better Explanations.
Hi there sorry for slow reply, been busy with work but ideally a battery as its small. But a call would be perfect, when would suit you?
